REDMAGIC Cyberbuds DAO TWS
Transform Your Sound and Gaming Experience with REDMAGIC Cyberbuds DAO TWS
We spent the first half of 2023 dropping new releases to make your gaming experience even better, with the introduction of the REDMAGIC 8 Series, the REDMAGIC PC Gaming line, the REDMAGIC Shadowblade Gamepad, and the latest REDMAGIC Turbo Cooler Gen 4. Now that we’re well into the year's third quarter, you can look forward to a few more tech pieces, starting with the new REDMAGIC Cyberbuds Dao TWS earphones.
Our latest flagship gaming headset maintains futuristic and understated aesthetics, completing the entire look of everything we’ve been working on throughout the year. Plus, it’s packed with specs that are guaranteed to elevate and transform your audio experience from the moment you unbox it.
First-Class Aesthetics
The REDMAGIC Cyberbuds Dao TWS headsets have the most unique look of all our accessories, channeling the REDMAGIC 8 Pro Titanium, Void, and REDMAGIC 8S Pro Platinum’s completely transparent design. It comes with a quirky, asymmetrically designed charging dock that permits wireless charging, plus a see-through case that’s engraved with a tech-inspired design.
The charging station has custom RGB lights that can be controlled using the special knob which also acts as the volume dial and a stand during wireless charging. The buds themselves have an ergonomic design that lets you comfortably wear them for extended gaming periods, and the transparent design does a fantastic job of showing off the mechanism and lights within the buds. You can customize the charging station by switching between the Colorful Gradient, Colorful Breathing Light, or Monochrome Gradient light modes.
A Qualcomm Powered Connection
The flagship Qualcomm Bluetooth 5.3 chipset has a dual-core 240 MHz processor that ensures a faster, more stable connection and delivers low latency and anti-jamming during a connection. We’ve paired the already powerful chipset with our self-developed algorithm to make the transmission of sound faster with a low latency of 28ms.
Additionally, the buds are fitted with the Qualcomm 2.4G Chip that has a dedicated game mode and is compatible with a wide variety of devices for a heightened sound experience whether you’re gaming on a smartphone, a PC, or a console.
Outstanding Sound and Control
The 11mm Linear graphene speakers of the REDMAGIC Cyberbuds DAO TWS headset have AI-powered active noise cancellation to deliver impressive and uninterrupted sound clarity by blocking out external noise. Additionally, the noise cancellation effect can be customized to suit different environments, with the ability to reach an ultra-low noise reduction depth of 48db.  They also boast custom sound effect certifications from Hi-res Audio, Snapdragon, and spatial game sound effects from DTSX to deliver an immersive sound field and 3D sound effects.
The audio buds support a dongle connection which allows you to pair to a multitude of devices without a Bluetooth connection. The charging dock has two separate ports that allow you to charge the device as well as connect a dongle. Overall, the buds can give you complete control of your sound experience for 7.5 hours thanks to the 350 mAh battery in the case and 35 mAh in each bud. You can also download and connect to the “GoPer” app for a wider range of control.
First-Class Aesthetics, Ultimate Performance
Get ready for the new flagship gaming headset that is set to revolutionize the way you hear the game. The REDMAGIC Cyberbuds Dao TWS earphones will retail for $229, and you can sign up to receive the notification as soon as they drop. For the full aesthetic effect, consider pairing our latest headset with the clean aesthetics of the REDMAGIC 8S Pro, coming this August.
From $64.00
From $64.00
From $39.00
From $39.00
