In the modern world, immersion is a critical part of the digital experience. We want to feel like we’re being whisked away into a new world whenever we look at a screen. This is why we place so much emphasis on display technology in the devices we build today. After all, the screen is your only window into every game, movie, app, and social media feed.
Now, while display technology has evolved significantly over the years in many ways, the debate between OLED and LCD remains. Although LCD technology has served the industry well for decades, OLED has emerged as a worthy opponent for more premium devices. Today, we’ll be exploring the difference between the two display technologies, why OLED is considered the gold standard today, and how REDMAGIC has elevated visuals using each one.
Understanding LCD Technology
LCD technology works by using a backlight positioned behind the display panel. Liquid crystals manipulate this light to create the images you see on screen. Now, because LCD panels rely on a constant backlight, every pixel is illuminated regardless of whether that part of the image is meant to be black or brightly colored. However, this also means that LCD technology struggles to achieve perfect black levels and often lacks the contrast and visual depth found in OLED displays.
LCDs are ideal for larger displays, like TVs and monitors, where flexibility and portability aren’t an issue. However, OLED displays are better suited to smaller, lightweight devices, such as smartphones and tablets. When it comes to gaming in particular, the OLED screen delivers superior color, contrast, and viewing angles to keep you entertained without compromising visual quality.
What Is an OLED Display?
The Organic Light Emitting Diodes (OLED) display is one of the most commonly used screens today. With an OLED display, each pixel emits its own light and can be controlled individually, a phenomenon called an emissive display. An OLED screen also uses a unique organic substance that glows with no need for a backlight, unlike common LCD screens.
By having each pixel independently lit, OLED displays ensure precise control over image quality. This ensures bright colors, fast motion, and high contrast, which is why they’re often found on high-end TVs, laptops, smartphones, and tablets. Now, let’s look at some of the core benefits of an OLED display. But how does this apply to the world of gaming?
Benefits of an OLED Display for Gaming
Gaming can be very demanding on hardware, with a need for high-speed processing, cooling mechanisms, endurance, and much more. However, the display should never be overlooked. With a capable display, gaming devices can effortlessly run the most graphically-intensive titles, capturing each moment with the right vibrance, fluidity, and contrast as intended.
For most fast-paced games, your display will directly impact the responsiveness of your screen to inputs. A higher refresh rate gives you exceptional agility and visual precision. The OLED display has a unique structure that enhances colors, contrast, and immersion for a more premium feel and refined look. These are some of the top benefits of using a gaming device with an OLED screen:
Agility Assured: As mentioned above, the OLED display tends to have faster refresh rates. In fact, one of OLED's greatest strengths is its incredibly fast pixel response time. Since pixels can change states almost instantly, OLED panels reduce motion blur and ghosting during fast-paced action, providing smoother gameplay.
Superior Contrast: Unlike an LCD that stays lit at all times, an OLED display simply turns off pixels when displaying the color black. This provides richer and more vivid colors with depth and realism. For gamers, this means darker environments appear more immersive.
Whether you're exploring a shadowy dungeon, sneaking through a tactical shooter, or watching a cinematic cutscene, an OLED screen enhances every visual detail, even in low light conditions.
Adding More Color: Because each pixel emits its own light, colors appear more saturated and lifelike. The modern OLED panel also supports a wider color gamut and advanced HDR technologies that bring content closer to the creator's original vision.
Whether you're watching movies, editing photos, streaming content, or gaming, OLED displays provide a more engaging visual experience. For competitive gamers, vibrant colors can also help to identify enemies, effects, and environmental details more easily.
See Things From a New Angle: LCDs often experience color shifting and brightness loss when viewed from off-center angles. However, OLED displays maintain color accuracy, contrast, and brightness much more effectively regardless of viewing position.
This makes the OLED screen ideal for multiplayer gaming sessions, watching videos with friends, and versatile viewing on the move. With OLED, your image remains consistent and vibrant even when viewed from the side.
Energy Efficiency: Without the need for backlighting, OLED displays consume much less power than their LCD counterparts. This helps to preserve the battery life of your gaming device in the long run.
Now that we know more about how OLED displays improve gaming, let’s see how we’ve designed our REDMAGIC devices to make the most of every pixel.
See a Brighter Future with REDMAGIC
At REDMAGIC, we see display technology as a critical part of the gaming experience rather than a simple design afterthought. This is why our gaming devices come with premium OLED displays. However, we’ve also used traditional LCDs along the way.
In terms of gaming tablet evolution, our OG Nova gaming tablet came fitted with a 10.9-inch LCD screen with a 2.8K high resolution. Now, at the time and till today, that was an impressive set of display specs for a new gaming tablet in the market. However, with the launch of our Astra 1, we switched to a high-quality OLED screen with a 165Hz refresh rate for richer colors, stronger contrast, and smoother graphics.
Now, we get to hype up our latest Astra 2 gaming tablet that comes fitted with a full-screen OLED display, ensuring enhanced brightness, stronger contrast, refined colors, and an up to 185Hz refresh rate. Our latest gaming smartphones, like the 11S Pro and 11 Pro, use premium AMOLED displays, which are simply a more enhanced version of the OLED you know and love.
When it comes to pushing the bar further with display technologies, we try to make changes that will have a tangible effect on gameplay, streaming, and the quality of your overall experience. For gamers seeking flagship-level visuals, our choice of OLED technology perfectly complements our focus on performance, cooling, battery innovation, and gameplay.
So, What’s the Verdict?
While LCD tech has been a staple for most devices and has left its mark on the industry, it’s important to always look further to stay ahead. This is why OLED displays have established themselves as the superior technology for modern devices, gaming or not. As display technology continues to evolve, OLED remains the benchmark for premium mobile devices, and it's a key reason why modern REDMAGIC gaming devices provide such an immersive and visually stunning gaming experience.
Q: What’s the difference between OLED and LCD?
A: LCDs use a backlight to illuminate pixels, while OLED displays allow each pixel to generate its own light independently.
Q: Why do OLED displays have better black levels?
A: OLED pixels can turn off completely when displaying black, creating true blacks and significantly improving contrast.
Q: Are OLED screens better for gaming?
A: Yes. OLED offers faster response times, higher contrast, better motion clarity, and more immersive visuals, making it ideal for gaming.
Q: Does OLED consume less battery than LCD?
A: It depends on the content being displayed. OLED can be more efficient when showing dark themes or black backgrounds because individual pixels can turn off.
REDMAGIC Astra 2 Magnetic Case REDMAGIC Astra 2 Magnetic Case
Level up your tablet protection with the REDMAGIC Astra 2 Magnetic Case. Designed for gamers, it features an airflow-enhancing open-frame structure, 3D protective design, and a powerful 3rd-generation carbon steel magnetic ring for secure accessory attachment.
$29.00
$29.00
$24.90
$24.90
