Technology has been rapidly evolving in the last few decades, and manufacturers have been straining to stay ahead of new demands. Every device built today has to meet a specific criterion to be deemed reliable, efficient, and worthy of your time. One of those critical elements in the smartphone industry has been the ever-advancing field of cooling technology.
After a long period of working, every device begins to generate heat; this is a simple fact that has guided the elevation of cooling tech across every sector. Now, a smartphone has several working parts condensed into a much smaller setting than your average laptop or PC. This means that it can and will generate heat a lot faster. This is especially common when it comes to gaming smartphones in particular.
In this blog article, we’ll be looking into cooling tech in smartphones and how it became such a crucial element in the modern gaming smartphone designs we see today. We’ll also be exploring the benefits of smartphone cooling and how REDMAGIC has elevated the cooling game industry throughout the years. For now, let’s get a better understanding of what we mean when we say smartphone cooling tech.
What Is Cooling Technology?
When we look at the history and science behind cooling technology, it’s easy to see how we got to where we are today. Cooling technology has its roots in the earliest iteration of the computer systems we see today. In 1964, the IBM System/360 required a specialized, built-in water-cooling system to maintain its cool operation while processing high-speed data in scientific applications.
After that, cooling systems were typically associated with larger computer models and PC rigs, where intensive processing was likely to occur. Essentially, cooling technology would do exactly what its name suggests: it would cool down devices. Rapid processing, advanced chipsets, and intensive settings forced most devices to add cooling components like graphene, vapor chambers, fans, and much more.
At the turn of the century, the smartphone era took off, pushing every person to invest in more advanced technology, connectivity, and communication. The tech world began to turn up the heat – quite literally – and cooling tech had to race to keep up.
Enter Smartphone Cooling
While the first prototype for a smartphone came in 1973, the concept of mobile gaming only came to fruition around 1997 with the game Snake. After that, smartphone designs quickly became more advanced and intelligent throughout the years, as well as their use in the gaming industry.
Now, smartphones are essentially pocket-sized computers with massive processing demands, flagship chipsets, AI enhancements, and much more. This naturally means that they accumulate a lot more heat as well, especially gaming smartphones.
Now, the average smartphone is designed to operate at its best between 0°C to 35°C (32°F and 95°F). For a gaming smartphone, the average temperature can easily reach up to 50°C during intensive and long gaming sessions. This is because your typical gaming smartphone is equipped to handle faster graphics, steadier frame rates, and a variety of gaming features optimized for performance above anything else.
This is why gaming smartphones are usually fitted with advanced cooling tech to make performance smoother while ensuring your comfort and safety during use. Smartphone cooling features come in different shapes and sizes depending on your needs.
Typically, these features use either passive or active cooling, where active cooling uses driven components like fans or pump systems to flush out heat, while passive cooling relies on heat transfer and thermal properties. These cooling systems provide a ton of benefits for your gaming smartphone in the long run.
Why Do We Need Smartphone Cooling?
Gaming smartphones are built to exceed typical performance expectations. This means that they build up a lot more heat in a shorter span of time. Here are some of the key reasons behind smartphone cooling tech today:
  1. Enhanced Performance: Your gaming smartphone’s chipset and processing setup need to provide the maximum power to keep up with demanding graphics and frame rates of most major 3A gaming titles. This means that your cooling system needs to keep up to ensure the smoothest and most secure performance during every task without any throttling.
  2. Lasting Power: Gaming smartphones go through the ringer when it comes to gameplay, and getting to the final boss battle will probably take some time. If your phone continues to heat up, you may have to take frequent breaks to allow it to cool down. With cooling tech in place, your smartphone can remain cool while you play, allowing you to play for longer.
  3. Better Longevity: Heat will actively damage any device over a long period of time. With advanced cooling in place, you can extend your device’s lifespan and protect it from any lasting damage.
  4. Improved Comfort: Naturally, a cooling solution allows you to hold and manage your smartphone without burning your fingertips or hands.
  5. Potential for Better Performance: When your smartphone packs advanced cooling tech, you can also load it up with the latest chipsets and software without batting an eye. Optimized cooling systems allow you to consistently improve designs, components, and performance without worrying about overheating.
  6. Enhanced Charging: A lot of the heat your smartphone generates can come from charging your phone. With cooling systems in place, your phone can seamlessly recharge without piling up too much heat along the way.
Keep Cool with REDMAGIC
At REDMAGIC, we have a long history of developing cooling solutions for our gaming smartphones and devices that emphasize innovation, excellence, and reliability. As a leading name in the mobile gaming industry, we are committed to improving, elevating, and prioritizing cooling solutions across our range.
Our latest flagship smartphone, the REDMAGIC 11 Pro, is a testament to our dedication to finding new ways to improve heat dissipation and elevate the gaming experience overall. As the world’s first mass-produced, liquid-cooled smartphone, the 11 Pro has already changed the cooling tech game forever.
Micron Laser-Cut Flow Channel Design in the REDMAGIC 11 Pro
Our AquaCore Cooling System has ushered in a new era of cooling, featuring the industry’s first mass-produced flowing liquid cooling system along with the use of upgraded liquid metal 3.0, the largest vapor chamber in the industry, and an ultra-fast REDMAGIC Turbofan.
Cooling technology has come a long way, but for smartphones, the road seems to have only just begun. At REDMAGIC, we’ll be doing our part to continuously innovate and elevate cooling solutions, creating a safer, more reliable, and performance-driven smartphone future for us all.
