At REDMAGIC, we understand that you’re always looking for the next best thing. Whether it's for gaming or everyday life, you expect a certain standard from our latest launches. After all, your experience is what counts in the long run. We could have a jam-packed list of specs, but if they don’t actually serve you, what good are they really?
This is why we approached our flagship 12 Pro with the understanding that our engineering and designs need to have tangible results in your routine. A great gaming phone should do more than just run a few games; it should keep up when the action gets intense, last through long sessions, and feel just as capable when you're catching up on messages, watching videos, or getting things done.
Today, we’re going to break down the upgrades in our new 12 Pro and expand on what they actually do to elevate your gameplay and experience. We hope that by the end of this article, you’ll know more than just a few facts about the phone and actually see the real-life benefits of choosing the 12 Pro as your new flagship favorite. First, let’s look at what drives the 12 Pro’s performance under the hood.
Flagship Performance That Goes Beyond Gaming
Imagine yourself playing an incredibly demanding open-world game while running voice chat in the background, or switching between a competitive match, your music playlist, and message notifications without wanting everything to slow down. These are the moments that need capable hardware and committed processing.
At the heart of our new 12 Pro is the Qualcomm Snapdragon 8 Elite Extreme Gen 6 chipset, which was just launched at this year’s Snapdragon Summit as the world’s first mobile CPU to hit 5 GHz. So, why does that matter? Well, the Snapdragon platform is responsible for all the heavy lifting that your phone does, from processing game logic to rendering detailed environments and managing demanding applications.
Built on next-generation Oryon CPU architecture and a 2nm process, the platform teams up with our Engine Cube 4.0 platform and our very own RedCore R5 gaming chip to ensure 33% lower latency. Together, these components support smoother visuals, responsive controls and more consistent gaming performance. Now, the 12 Pro is also powered by our first-ever G1 high-refresh-rate display control chip, which enhances display performance and enables the phone’s ultra-smooth up-to-185Hz refresh rate.
In practical terms, a chipset and processing power like this give demanding games more performance headroom and allow the phone to handle intensive everyday tasks. It also creates room for more complex mobile gaming experiences as developers continue pushing graphics and gameplay further. Of course, raw processing power is only one part of the story. A flagship phone also needs to manage that power effectively over time, which is where cooling comes in.
Meet AquaCore 3.0: Where Performance Flows
One of the cooler – pardon the pun - details of our newest REDMAGIC devices is the inclusion of our pioneering liquid cooling systems. Since the 11 Pro, we’ve been dazzling the industry with new and innovative liquid-cooled setups, rightfully earning our spot at the cutting edge of mobile cooling technologies. But enough about us, let’s talk about what cooling does for you.
It doesn’t take a genius to understand that cooling is meant to keep your device cool. To combat thermal throttling and tech-killing heat levels, cooling systems work their magic to dissipate heat in many ways. The 12 Pro just happens to be the industry’s only smartphone to use both airflow and liquid flow to stay cool, implementing a new dual-loop flow channel design within the AquaCore 3.0 cooling system. This replaces the previous single-loop structure for more efficient thermal management.
This new through-flow design uses a fan to allow the liquid-cooling system to extend across the motherboard and vapor chamber area, enhancing heat dissipation. While it looks really cool, this wasn’t just an aesthetic choice. The upper and lower loops now fully cover both the battery and chipset while the dual-crystal micro pump ensures 27% higher heat-spreading efficiency when compared to the 11 Pro flow design. This new design also provides 130% larger flow channel area, increasing the flow channel thickness by 25% and the volume by 189%.
Naturally, we had to add some ambience to our new flow with customizable RGB lighting integrated beneath the liquid-cooling loops, so your flow can change colors now too. But back to the cooling system, the 12 Pro also sports an upgraded 25,500 RPM turbo fan with a labyrinth dust-resistant design and a reinforced fan shaft for faster heat dissipation and enhanced stability.
To add to the cooling arsenal, Liquid Metal 4.0 is embedded in a copper foil substrate to ensure a stable composite structure that won’t shift and reaches a larger contact area. The phone also features the industry’s first advanced, raised-step vapor chamber architecture, with no fill ports or dead zones, improving thermal conductivity by 50%. This is basically like stretching out the cooling element to cover more ground and get rid of heat evenly and effectively.
The main benefit of the new system isn't simply a lower number on a temperature chart or a cool new flowing effect to show off. The 12 Pro was built to ensure effective thermal management that helps the device sustain demanding workloads more consistently, especially for demanding gaming sessions. Now, let’s see what the display has cooked up for us.
See Yourself in the Action
Your screen display is where everything comes together. It's the only glaringly visible upgrade you can notice from the start. For gamers, display is a critical feature, handling how you track an opponent, navigate a complicated environment, or appreciate the details developers put into a game.
The 12 Pro features a 6.85-inch 1.5K OLED display using BOE X11 under-display emissive material, with 0.96mm bezels and a 96.3% screen-to-body ratio. That’s a lot of numbers and specs right there, but let’s start simple.
The full-screen display and slimmer bezels basically provide more immersion and edge-to-edge visuals. This allows the content on the screen to take focus, not the frame of the phone. By keeping the front display free from a conventional camera cutout, the UDC tech also provides a seamless finish and uninterrupted viewing.
Now, a display's refresh rate describes how many times it can update the image each second. The 12 Pro boasts an up-to-185Hz refresh rate, which means that the screen can refresh up to 185 times per second, delivering smoother motion in supported content. SGS eye care certification also reduces eye fatigue and strain, for a more comfortable viewing experience.
With a 5,000Hz instantaneous touch sampling rate and Synaptics touch chip, the screen is designed to capture touch input with ultra-low latency. This helps capture touch input quickly for responsive control. This improves agility and speed for fast reactions in competitive gaming.
Imagine following an enemy moving across the screen or needing to make rapid adjustments while aiming. When a game supports high frame rates and your 12 Pro can deliver them, a high-refresh-rate display makes movements feel buttery and interactions more immediate. It’s also important to note that a 185Hz display doesn't automatically mean every game runs at 185 frames per second. Actual frame rates will depend on game support, software optimization, and your device settings. Now, let’s look at the power stats on this powerhouse.
Let the Power Talk
Powerful hardware is great, but it isn't much use if you're constantly looking for a charger. For mobile gamers, or anyone really, battery capacity is a major highlight in a new phone. Demanding games, AI workloads, remote working, internet connectivity, and high-graphics streaming can all consume considerable amounts of energy. This is exactly why we packed the 12 Pro with an upgraded 8,400mAh battery, giving it substantial capacity for gaming and everyday use.
Now, a larger battery gives you more energy to work with and can be useful when your day involves a mix of gaming, video streaming, navigation, messaging, and other everyday tasks. The 12 Pro also supports bypass charging for safer gaming as you power up, alongside 80W wireless fast charging for a convenient way to recharge without cable clutter, making it ideal for anyone who prefers a tidier desk setup.
A Design That Elevates Performance
At REDMAGIC, we’ve always embraced a distinctive visual gaming identity, and the 12 Pro continues that approach with a futuristic design that looks powerful and feels effortless to hold. Weighing just 223g, the 12 Pro provides a premium look that’s easy on the hands and even easier on the eyes. Enjoy a notch-less full-screen display with a dual-sided, flat design and no camera bump in sight, where a transparent back design with visible liquid cooling and dynamic RGB lighting sets the tone for your next victory.
Rather than treating the phone as an ordinary device with a few gaming features added, it’s designed to reflect the engineering inside by giving you a glimpse of what’s happening inside your phone through the visible flow. Now, let’s focus on the gaming element.
Gaming Features Built Around How You Play
With its latest Snapdragon platform and our R5 gaming chipset, the 12 Pro is already leagues ahead. But it’s the combination of its elements that make it a force to be reckoned with. While the powerful processor supports demanding graphics and complex gameplay, the high refresh rate helps compatible games deliver smoother motion, and the dual-loop cooling manages heat during intensive sessions.
This is especially relevant for players who enjoy a mix of competitive multiplayer titles and graphically demanding single-player adventures. While each type of game places different demands on the hardware, they all benefit from a system designed with performance in mind. The phone’s 520Hz ultra-responsive shoulder triggers also offer fast, precise input, designed for high-speed FPS and MOBA gameplay. So, is it just the gamers that’ll get a kick out of the 12 Pro? Well, far from.
Is the 12 Pro Just for Gamers?
Simply put, no. While gaming remains at the heart of what we do, we built this flagship phone for everyone, capable of handling demanding workloads well beyond gaming. A key element of the 12 Pro is that its performance-focused identity doesn't have to limit how you use it. It can be built for demanding games, but that same processing power can also support everyday multitasking, entertainment, and productivity tasks.
That's where the idea of a performance flagship becomes interesting. The same engineering that supports demanding gameplay can also help create a capable everyday experience. For people on the go or with hybrid working situations, the 12 Pro offers versatility you couldn’t find elsewhere.
The 12 Pro supports versatile connectivity, with a 360° omnidirectional antenna design, Wi-Fi 7 support, alongside dual SIM, NFC, Google Pay, and fully-loaded USB 3.2 Gen 2 capabilities. The phone also carries IP68 and IP69 ratings for dust and water resistance, while the cooling-fan area is separately rated IPX8 dust- and water-resistant under certain conditions, making it easy to take wherever you need to go.
You can also expand your viewing with effortless second-screen support for displays and control on tablets, while staying secure with 3D ultrasonic fingerprint unlocking and IR Blaster support for control of your smart home. Get assistance wherever you are with AI by Google Gemini that provides AI photo search, image editing, Circle-to-Search, and real-time translations. Armed with REDMAGIC OS 12, based on Android 17, the 12 Pro is designed for a smooth and intuitive daily experience.
Immerse Yourself and Capture Every Moment
The 12 Pro expands your immersive gaming experience with Dual 1115E stereo speakers with Dolby Atmos deliver immersive audio, while an 0815 X-axis linear motor provides responsive haptic feedback. Essentially, the superior audio and vibrational feedback add a layer of gravity to your gameplay, but also to your streaming expectations.
Now, we know that gaming phones get a bad rep when it comes to camera features, but the 12 Pro is meant to fit into your day-to-day life in the best way possible. With a 50MP main camera with OIS support, a 50MP ultra-wide camera, and a 16MP front camera, you can take advantage of our optimized imaging algorithms for enhanced photo quality, alongside stable, clear, and versatile shooting for all your cherished daily moments, from photos of your lunch to video calls with loved ones.
So, Are You Ready for a New Flow?
Our new 12 Pro combines several upgrades with a common purpose: making high-performance mobile gaming more practical for everyday use. While each feature has its place, together they form a smartphone designed around your experiences and your expectations. This is what makes the 12 Pro an appealing choice.
It's not just about having impressive specs on paper; it's about building a device that can put those features to work when you need them most, whether you're on a winning streak in your favorite game or simply getting through a busy day. Because a performance flagship should always be ready for more than one kind of challenge, and the REDMAGIC 12 Pro is always game for that.
Q: What chipset does the REDMAGIC 12 Pro use?
A: The Qualcomm Snapdragon 8 Elite Extreme Gen 6, paired with the REDMAGIC R5 gaming chipset, is designed to support demanding games, advanced graphics, and responsive everyday performance.
Q: What is the AquaCore 3.0 cooling system?
A: The 12 Pro's pioneering dual-loop liquid cooling system, featuring an upgraded turbo fan, a large vapor chamber, and Liquid Metal 4.0.
Q: What does the REDMAGIC 12 Pro’s up to 185Hz display mean for gaming?
A: It means the display can refresh up to 185 times per second, allowing compatible games to deliver exceptionally smooth motion.
Q: How large is the REDMAGIC 12 Pro's battery?
A: It has an 8,400mAh battery and supports 80W wireless fast charging.
Q: Does the REDMAGIC 12 Pro have a 3.5mm headphone jack?
A: No, it does not. It features a Type-C port.
Q: Is the REDMAGIC 12 Pro suitable for everyday use?
A: Yes, its flagship processing platform, large battery, and full-screen AMOLED display make it suitable for a range of activities beyond gaming, including streaming, multitasking, browsing, and communication.
