A-Completely-Flat-Design-with-All-the-Edge
A Completely Flat Design with All the Edge
Must a gaming device be massive to contain all the components you need to excel on the virtual playing field? If you’re trying to create the ultimate gaming smartphone that doubles as a daily driver, like the REDMAGIC, then this is one of the main things you need to consider.
There’s no denying that a massive battery and screen are prime requirements, so how do you go about making that happen in a device that’s small enough to fit in your pocket? By making it completely flat.
Seamless Design Evolution
One of the standout features of the REDMAGIC 9 Pro is the flush design of the rear panel, something that we had previously achieved in the REDMAGIC 7 Series. We took it up a notch this time by incorporating a rear glass panel that takes the completely flat aesthetic to the next level.
A Beast and a Beauty
While the Android Police had previously celebrated the return of the protruding camera set up in the REDMAGIC 8 Series, they too admitted that the flat design would be more appealing to gamers, and so we brought it back. Though it may have been challenging to successfully squeeze all the components into a space less than 9mm thick, it was a challenge worth conquering.
In his YouTube review of the device , Daniel of Daniel’s Tech Studio expresses that the REDMAGIC 9 Pro boasts one of his favorite smartphone designs of all time. He describes it as a smooth slab of metal and glass, the cleanest design he’s encountered in a long time. He attributes the unique look to the seamless back panel that matches the notch less full screen with a hidden selfie camera.
The 6.8 inch screen not only looks beautiful but also works like a dream to make the gaming experience more memorable. According to the TechRadar review of the REDMAGIC 9 Pro’s screen, our decision to incorporate the BOE 9+ Luminescent screen delivers a display with more punch, a feature that makes for more immersive gaming.
All the Power Lies Under the Hood
While aesthetics are quite important, the most important part of the gaming smartphone is its performance, as reiterated by Daniel in his review. The powerful Snapdragon 8 Gen 3 chipset, the heart of the machine and the driving force behind the 120 Hz screen refresh rate, doesn’t go unnoticed under the see-through hood of the transparent versions. However, it’s not the only powerful thing on display.
Right underneath the beautifully compacted dual 50 MP camera lenses sits an improved 22,000 RPM turbo fan, the foundation for one of the most powerful built-in cooling mechanisms in a smartphone. The REDMAGIC 13.0 Cooling System is 5 degrees colder than the previous generation, making the REDMAGIC 9 Pro easily one of the coolest gaming smartphones in the market.
Many will agree, however, that the most formidable feature in this generation of REDMAGIC devices is the 6500 mah battery that fuels every other component. All this power, as well as the device’s fast charging capabilities, sits comfortably cool in the ultra thin setup of the REDMAGIC 9 Pro.
With a completely flat design and powerful components, the REDMAGIC 9 Pro combines sleek design with unmatched performance setting a new standard not only for gaming smartphones, but also our trusted daily drivers.
Sleek Design, Powerful Performance
As we pondered the necessity of massive batteries and screens, we realized that size alone shouldn’t dictate a device’s capabilities. Our solution was to embrace innovation and push the boundaries by crafting a completely flat design that defies expectations.
While the protruding camera setup of the REDMAGIC 8 Series had its appeal, we recognized the allure of a flat design, particularly for gamers seeking a seamless experience. The journey from the REDMAGIC 7 Series to the REDMAGIC 9 Pro has been one of evolution and refinement. Through meticulous engineering and design ingenuity, we successfully compressed all essential components into a space less than 9mm thick, a feat that underscores our commitment to excellence.
Reviewers and users alike have commended the REDMAGIC 9 Pro’s design, describing it as a harmonious blend of beauty and brawn. The smooth slab of metal and glass, complemented by the notch-less full screen and hidden camera, exudes a sense of refinement and sophistication rarely seen in the smartphone market.
Innovation Unleashed
The REDMAGIC 9 Pro represents the culmination of our relentless pursuit of perfection. Welcome to a new era of gaming excellence, where innovation knows no bounds and performance reigns supreme.
REDMAGIC 9 Pro
From $119.00
From $119.00
From $64.00
From $64.00
