Turn-Your-REDMAGIC-10-Pro-into-a-Gaming-Beast-with-These-Power-Tips
Gaming is often viewed as a hobby or simple pastime to many; however, it can also be demanding for most avid gamers. This means that you need to use advanced tools to ensure the best gaming experience and to secure your victory. Fortunately, REDMAGIC is precisely in the business of creating innovative and inspired devices that will seamlessly elevate every gaming session you encounter. In this blog, we explore the specific ways that you can push your REDMAGIC 10 Pro to the limit when it comes to winning – for a smoother, more powerful, and enhanced grind that keeps you on top.
REDMAGIC 10 Pro: A Gaming Beast
In his IGN review, Mark Knapp put it best when he described the 10 Pro as “beastly” when it came to gaming and performance. The Snapdragon 8 Elite chipset built into the gaming smartphone elevates it to new levels of power by boasting a seamless 45% boost in performance while the upgraded UFS 4.1 Pro and tech deliver 3% faster read speeds and 10% quicker write speeds for seamless multitasking and faster loading times.
However, this powerhouse gaming device can also thank REDMAGIC’s first AI-powered chip, the Red Core R3, for providing faster processing and seamless visuals with double frame insertion, 2K upscaling, and AI-driven stabilization. Now let’s look at some of the more specific ways you can elevate your game with the 10 Pro’s beastly capabilities.
Frame Rate Boosting
Frame interpolation allows your device to generate additional frames between the ones natively rendered by the game – ensuring a smooth boost in perceived frame rates and overall visual quality with every movement on the screen. This visual upgrade in the 10 Pro ensures that you can play demanding AAA games, like Genshin Impact or FPS games, with ease and at an even faster rate than the game allows.
To activate the 10 Pro’s Frame Rate Boost for interpolation, users need to simply switch on Rise or Diablo Mode in their phone’s Game Space menu. This pushes the device to perform at its peak and offers seamless frame rate boosting for smoother visuals. Currently, this feature is compatible with several popular games - including Genshin Impact, COD Mobile, Clash of Clans, Wild Rift, Honkai Impact 3, and Arknights – however, REDMAGIC has plans to add many more games soon!
Eco, Balance, Rise, or Diablo: A Mode for Every Occasion
Now one of the standout features of every REDMAGIC device is the different modes and systems you can choose to optimize performance to best suit your needs. The REDMAGIC 10 Pro comes with 4 modes that are customized to help you get the best out of every session.
Eco Mode: This is the more reserved system built for users who are trying to preserve battery life above all else. In Eco Mode, power consumption is drastically minimized to extend your device’s battery life. Typically, this mode should be activated if you’re traveling or have limited access to a power source.
Balance Mode: As its name suggests, Balance Mode is all about finding a middle ground when it comes to power usage and performance. In Balance Mode, you optimize and conserve battery life while still providing high-end performance. This is mostly used for regular gaming on a day-to-day basis.
Rise Mode: Now, this is where the gaming starts to heat up. Rise Mode is built to maximize performance and handle demanding games and gaming sessions. This is ideal for graphically demanding and fast-paced gaming and uses more battery to provide the best performance.
Diablo Mode: This is a special mode configuration that you need to unlock to use effectively. Diablo Mode is essentially the highest performance level you can push your REDMAGIC device to. This hidden gem unleashes an overclocked performance to provide a significant boost in power. However, you play with the devil and you might get burned as your phone will start generating significantly more heat in this setting. This is why Diablo Mode comes with a warning not to be used for extended periods. Magic Gaming Phone illustrated the performance power of Diablo Mode on his channel and how it can be used to absolutely elevate the full potential of the device.
Sourced from Magic Gaming Phone
Powerful Plugin Power
YouTuber, Demonal, tested out the REDMAGIC 10 Pro with PUBGM in a review and made specific use of some of the plugins available for the game. He shared that users could easily adjust the power between Eco Balance and Rise Mode or just use Diablo Mode alone to boost the CPU and GPU power to 100%. Some of the plugins you can easily use to elevate your gaming experience with the 10 Pro include:
  • Scout Mode: Enhances targeting precision by zooming in on distant enemies for better visibility.
  • Auxiliary Line: Improves shooting accuracy by allowing players to set benchmarks on the screen.
  • AI Trigger: Enable automatic actions for instant and responsive gameplay.
  • Custom Crosshair: Allows users to personalize their crosshair in shooting games to enhance aiming precision.
  • Counter & Game Event Tracking: Allows users to track the gacha pull counts per session while logging critical gameplay moments like zone shrinking, revival counts, and displaying a floating window on the game interface to mark key events for better in-game awareness.
  • Flexible Recording: Captures gameplay moments with precision through forward or backward recording - enabling different event-based recording directions - such as backward recording for kills and forward recording for gacha pulls, while also allowing players to customize the recording length before and after a triggered event.
  • Screen Extraction: Displays critical in-game information in whichever convenient viewing location is chosen by the player – rather than in the typical hard-to-see corners you’d usually find it.
  • Custom Display: Allows users to adjust the aspect ratios between Fullscreen, 4:3, 16:9, or Original, force landscape, or portrait mode - optimizing their view and even uncovering hidden game content that only appears after switching ratios. This plugin is optimized for tablets and foldable devices for seamless adaptation for larger screens.
  • Pre-Download Resource Packs: Allows users to seamlessly download game updates in advance – removing the waiting time for game launches and automatically downloading when your screen is off, your device is charging, and the Wi-fi is connected. If a download is incomplete when a game is launched, it will simply continue in the background to ensure a seamless gaming experience.
Each of these plugins helps in some way across every game and will make winning easier with more tools, skills, and capabilities at the tip of your fingers.
Frosty Cooling
One of the trademarks of the REDMAGIC brand is superior cooling capabilities. Now, the 10 Pro is no exception to this rule. With its cutting-edge ICE-X cooling system, the device remains at a constant cool through a multi-layered thermal solution that effectively dissipates and controls heat management during demanding gameplay. However, if you’re looking to push your 10 Pro further when it comes to cooling, you can easily invest in a REDMAGIC Cooler as well.
The REDMAGIC VC COOLER 5 Pro adopts a newly designed heat dissipation solution with a 3D VC liquid cooling architecture to ensure uniform and rapid cooling. Your phone will see a seamless temperature drop of up to 35℃ during heated gaming sessions, delivered by a VC Liquid Cooling Plate, intense airflow from the 7-blade fan, and a custom REDMAGIC TEC chip.
Attaching a cooler is also essential if you choose to use Diablo Mode frequently on your phone to prevent overheating and damage. REDMAGIC is also excited to be releasing its Cooler 6 Air soon as well.
Designed to Enhance Every Moment
The REDMAGIC 10 Pro already comes with an ergonomic and sleek flat back panel devoid of any uncomfortable camera bumps and a wide and immersive screen without any notches. The device’s 520Hz glass shoulder triggers also provide precise control for FPS games. However, there is another way you can elevate the design of your 10 Pro for a better gaming experience.
Enjoy exceptional gaming when you pair the REDMAGIC 10 Pro with the Shadow Blade Gamepad 2 for a console-like experience that provides optimal agility, comfort, and precision playing. With the gamepad and 10 Pro, you can enjoy customized gameplay while protecting your battery with charge separation that allows you to safely charge your phone as you game.
Gravity-X is also a fixed feature on REDMAGIC phones and facilitates smooth connectivity to external devices such as emulators and monitors to enhance your gaming experience. This allows you to enjoy games with higher graphics on a larger screen for better visuals and more control.
Step Up Your Game with the REDMAGIC 10 Pro
REDMAGIC devices have consistently provided high-quality gaming and advanced features that make every gaming experience a winning one. Now, the 10 Pro has elevated each game with several features of its own to make winning easier, smoother, and better.
$9.90
$9.90
