REDMAGIC-9S-Pro-How-Far-Does-a-6500mAh-Battery-Get-You
When it comes to gaming phones, battery life is a major factor to consider. The battery of your gaming phone will determine your performance and how long you can keep your winning streak going. Essentially, the battery life you get from any gaming phone will depend on how you use the device and the types of games you play – more demanding games will drain your battery faster and require a larger size. So, how do you figure out what battery would suit your needs in a gaming phone?
The milliampere-hour – or mAh – is a unit of electrical charge commonly used to measure battery capacity. Commonly described as the size of a battery's fuel tank, this unit will measure the total amount of energy the battery supplies in an hour when fully charged. For a gaming device, the battery life needs to keep up with fast processing demands, complex graphics, and more. According to Carl Care, gaming demands substantial power and a high-capacity battery of 5000mAh or more. This allows for extended gaming sessions without worrying about running out of battery mid-game.
A 6500mAh Battery Powerhouse
Fortunately, the REDMAGIC 9S Pro comes fully equipped with an impressive and industry-leading 6500mAh battery that ensures a legendary level of power and performance. With up to two days of non-stop endurance on a single charge, you can keep the game going with a battery that goes just as hard as you do.
Keep your REDMAGIC 9S Pro charged and ready to go with 80W fast charging that gets you from zero to fully charged in just 35 minutes. Josh Render for Tom’s Guide went out of his way to mention the battery powerhouse that is the REDMAGIC 9S pro by stating that the massive 6,500 mAh battery combined with the power conservation that Snapdragon 8 Gen 3 chips excel at ensures that you have a phone that you can happily run all day with no issues. He further went on to demonstrate the superior battery life by running the phone for more than 3 hours and having the battery barely drop by 15%.
Unparalleled Power
Lewis Painter went on to name the REDMAGIC 9S Pro the “Best Overall Gaming Phone” and cited the device's incredibly fast performance, massive battery, brilliant software gaming enhancements, and console mode and PC connectivity. Painter described the 9S Pro as one of the most powerful gaming phones ever tested with the Snapdragon 8 Gen 3 Leading Version that could go toe-to-toe with competitors despite being more affordable. In his review, Luke Baker attested that the gigantic 6500mAh capacity allows the gaming phone to have one of the largest battery packs of any modern phone – proven when battery benchmarks against competitors and the previous REDMAGIC 9 Pro.
Courtesy of Trusted Reviews
PCMag also ran tests proving that the REDMAGIC 9S Pro has one of the biggest batteries in the game that lasts almost three hours longer than the runner-up, the Asus ROG Phone 8. In the battery rundown test done, PCMag streamed a 1080p video at full brightness and saw that the REDMAGIC 9S Pro lasted for over 15 hours. The 9S Pro also managed a full recharge in just 45 minutes using the 80W included charger.
The phone further boasts a novel Charge SEP mode that allows you to power your phone via the USB-C cable without actually charging the battery – which is a great way to game while ensuring long-term battery health. GSM Arena further mentioned that the overclocked chipset in the REDMAGIC 9S Pro does take its toll on battery life, but that the impact is mostly limited.
Courtesy of GSM Arena
Choosing a Battery That Lasts
Gaming phones see a lot of action when it comes to power-hungry gaming, processing, and applications. This means that your ideal gaming phone needs the battery capacity to pull its weight and provide the seamless gameplay you deserve. The REDMAGIC 9S Pro is leagues ahead when it comes to power that truly carries your game to the next level. Choose superior battery technology that endures so you can keep winning.
