Exploded 3D view of the REDMAGIC 12 Pro showing its AquaCore Cooling System 3.0, dual-loop liquid cooling channels, vapor chamber, and airflow.
Gaming smartphones are continuing to evolve to meet increasingly demanding titles, more complex graphics, and longer gaming sessions. However, as processing power increases in complexity, so does one of the biggest challenges in smartphone engineering: heat management. At REDMAGIC, our cooling systems have always been about more than simply keeping temperatures under control. They’re also designed for sustained performance, helping players enjoy demanding games without unnecessary thermal limitations.
Now, with the REDMAGIC 12 Pro fresh on the market, we’d like to introduce you to our latest cooling endeavor with the AquaCore Cooling System 3.0. Combining an innovative dual-loop, liquid-cooling architecture with Liquid Metal 4.0, an advanced vapor chamber, and an upgraded turbo fan, this integrated system pioneers a new approach to managing heat across the device. But how does it all work? Let's go inside the 12 Pro and explore the engineering behind the cool.
Our AquaCore Cooling System 3.0 Introduces Dual-Loop Flow
At the heart of the 12 Pro's thermal architecture is the AquaCore Cooling System 3.0, featuring an advanced new dual-loop, liquid-cooling design. Now, liquid cooling works by circulating a cooling fluid through dedicated pathways to transport heat away from important components. Rather than relying exclusively on passive heat transfer, this approach introduces a more direct way to move thermal energy throughout the device.
The 12 Pro’s dual-loop, top-and-bottom architecture takes this concept further by using an all-new dual-crystal micro pump to provide powerful, consistent coolant circulation and expand the liquid’s coverage beyond traditional chipset-focused cooling. The output flow pressure is up from 100 to 130 kPa, allowing the coolant to travel faster and further.
Now, the thicker upper and lower loops also fully cover both the battery and chipset, ensuring a 130% larger flow channel area, which improves overall heat dissipation and increases heat-spreading efficiency by 27%. This design replaces the previous single-loop structure we debuted on the 11 Pro. The channels also extend into the airflow area where the turbo fan rapidly expels heat from the device, achieving synergistic liquid and air cooling.
Within the ultra-fine liquid channels, we use the same fluorinated liquid found in innovative AI servers, allowing it to stay stable and efficient from -60°C to 108°C, offering anti-freezing and anti-vaporization properties while maintaining electrical insulation and efficient heat transfer. The loops have also been re-engineered with an RGB pulsating halo that brings the cooling engine to life, allowing you to choose the color of the flowing coolant and combining functional design with our signature gaming aesthetic.
Now, the concept of using AI-grade-server liquid cooling inside a smartphone has always been a tricky idea, as smartphones move around a lot more than a stationary desktop PC would, are a lot more compact, and have to handle different temperatures and real-world durability situations. This is why the cooling system is housed inside a durable, leak-proof, and fully sealed system.
To combat the smaller playing field, the 12 Pro uses an upgraded dual crystal piezoelectric ceramic micropump with micron-level laser cutting technology to create ultra-fine liquid channels inside the device’s body. This creates the room needed for the coolant to flow effectively. Then, to ensure flow without resistance, we found the optimal balance between driving force and compact size after continuous testing of liquid-cooling channel membranes.
Drop resistance was also a core obstacle to liquid cooling in smartphones, however; we used an industry-first, ultra-low-temperature bonding process and a new anti-puncture membrane which allowed the 12 Pro’s liquid cooling system to pass tens of thousands of drop tests, ensuring real-world durability. To get ahead of the temperature issue, we use the same fluorinated liquid found in major cutting-edge AI servers, which stays stable, resistant to heat and chemicals, and non-conductive to prevent short-circuiting and ensure safe and reliable cooling in any situation. Now, let’s take a closer look at the other components that dispel heat from the 12 Pro.
Transfer Heat Better with Liquid Metal 4.0
Effective cooling starts with transferring heat away from the components generating it. This is where Liquid Metal 4.0 plays an important role. This advanced thermal interface material transfers heat away from the chipset and toward the wider cooling structure. This is particularly important because the processor is one of the biggest sources of heat during demanding gaming sessions.
When a game pushes the CPU and GPU, temperatures can rise quickly. Efficient heat transfer helps prevent excessive heat from concentrating around the chipset, allowing the wider cooling system to manage the thermal load. In the 12 Pro, Liquid Metal 4.0 comes embedded in a copper foil substrate with a stable composite structure to prevent shifting and leakage.
When compared to Liquid Metal 3.0, it also has 337% higher thermal conductivity and a 560% larger contact area for stable heat transfer. Ultimately, you can think of Liquid Metal 4.0 as a crucial part of the 12 Pro’s cooling journey. Before heat can be distributed throughout the device by the other components, it needs an efficient route away from the processor, and that’s where Liquid Metal 4.0 shines.
Distribute Heat With an Upgraded Vapor Chamber
Once heat has been transferred away from the chipset, it needs to be distributed across a larger area by the vapor chamber. This flat, sealed thermal component uses phase-change technology to move heat. Inside, a working fluid absorbs heat and evaporates. The resulting vapor then travels toward cooler areas, where it releases heat and condenses back into liquid.
An internal wick structure then helps return the liquid to the hotter region, allowing the process to repeat. This continuous cycle helps distribute heat rather than allowing it to accumulate around one small component. The 12 Pro comes with the industry’s first advanced vapor chamber architecture, featuring no fill ports, no dead zones, and a raised-step design that leads to a 15% larger effective cooling area and 50% higher thermal conductivity.
Here, the vapor chamber works alongside the dual-loop liquid-cooling architecture to support broader heat distribution. Within such a compact gaming smartphone, where thermal management must cover multiple internal zones without compromising the overall design, the VC is even more important. By providing another layer of heat management, it helps the 12 Pro handle the heat generated during intensive workloads.
An Upgrade That Will Blow You Away
Now, absorbing and distributing heat is only half the job. Eventually, that heat needs to leave the device, and that’s done with a fan. At REDMAGIC, we’re known for developing signature turbo fans, which means that the 12 Pro obviously had to get special treatment with an upgrade.
Working alongside the AquaCore Cooling System 3.0 to support the overall heat-dissipation process, the 12 Pro sports a 25,500 RPM high-speed turbo fan that actively moves air through the phone's internal cooling structure, carrying heat away from internal cooling components.
The fan features an exclusive labyrinth design, reinforced fan shafts, and an IPX8 water- and dust-resistance rating, delivering faster heat dissipation, enhanced stability, and 30% greater durability. This combination of air and liquid cooling is what makes the 12 Pro’s AquaCore Cooling System 3.0 interesting. While liquid cooling transports heat, the vapor chamber helps distribute it, and the turbo fan supports active heat dissipation. Each component has a different responsibility, but why is it all necessary?
Why Does the REDMAGIC 12 Pro Need Advanced Cooling?
Every demanding task generates heat. When you're playing graphics-intensive games, the CPU and GPU work harder to process game environments, render visuals, calculate physics, and respond to your inputs. The more intensive the workload, the more heat these components produce. This is a well-known fact about any device.
Now, when you combine the latest Snapdragon 8 Elite Extreme Gen 6 chipset, a 1.5K 185Hz full-screen OLED display, an 8,400mAh battery, and dedicated gaming features built for demanding gameplay, you get quite the powerhouse of a device in the 12 Pro. This means you need quite the cooling system to manage such an elaborate smartphone. Enter the AquaCore Cooling System 3.0.
The 12 Pro's dual-loop architecture expands cooling coverage over important components, while the larger vapor chamber, upgraded fan, and Liquid Metal 4.0 dissipate and expel heat from the overall device. Remember, the end goal for the 12 Pro’s cooling system isn't simply to cool one component as quickly as possible; it’s to manage heat throughout the device while balancing performance, endurance, and everyday usability.
A Complete Cooling Ecosystem
The real strength of the 12 Pro's AquaCore Cooling System 3.0 isn't any single component, but how the different technologies work together. These technologies were chosen with precision to form a coordinated cooling ecosystem designed around the thermal demands of modern mobile gaming.
As mobile gaming hardware continues to evolve, cooling will always be a hot topic and a key part of delivering consistent performance. New technologies create new expectations for smartphone cooling, and at REDMAGIC, meeting those expectations means looking beyond what’s possible today to what could be tomorrow.
Q: What is the AquaCore Cooling System 3.0 in the REDMAGIC 12 Pro?
A: An advanced and integrated REDMAGIC cooling architecture with visible dual-loop liquid cooling, Liquid Metal 4.0, a larger vapor chamber, and an upgraded 25,500 RPM turbo fan.
Q: How does dual-loop liquid cooling work in the REDMAGIC 12 Pro?
A: The dual-loop system uses a dual-crystal micro pump to circulate AI server-grade fluorinated liquid coolant through thicker top and bottom looped pathways that cover both the chipset and battery, ensuring improved heat dissipation.
Q: What is Liquid Metal 4.0, and what does it do?
A: It is an advanced thermal interface material designed to improve heat transfer away from the chipset. It helps move heat toward the wider cooling structure, where other components can distribute and dissipate it.
Q: What is the purpose of the vapor chamber?
A: To distribute heat across a larger surface area through phase-change processes by absorbing heat, moving it through internal vapor circulation, and releasing it in cooler areas, helping prevent excessive heat concentration.
Q: How does the 12 Pro’s turbo fan improve cooling?
A: It provides active airflow through the phone's cooling structure, moving heat away from internal cooling components and toward the exhaust, complementing the liquid-cooling system and vapor chamber.
Q: Can the REDMAGIC 12 Pro cooling system prevent overheating during gaming?
A: The AquaCore Cooling System 3.0 is designed to manage heat and support more consistent performance during demanding gaming sessions. Its effective cooling helps manage thermal buildup but cannot eliminate heat entirely.
Winner Announcement For REDMAGIC 12 Pro Sign-Up & Launch Game!
Thank you to everyone who signed up for and participated in the REDMAGIC 12 Pro Sign-Up & Launch Game! After thousands of entries, we’re excited to reveal our lucky winners.
Congratulations to all the winners! We can’t wait to hear about your experiences with the REDMAGIC 12 Pro and other prizes. We’ll notify the winners by email, so please keep an eye on your inbox!
Social Media Winner
REDMAGIC 12 Pro (12GB + 256GB)
@MikeFlyForever
Sign-Up Winner
REDMAGIC 12 Pro 12GB Nightfreeze Full Refund
game************alph@gmail.com
Launch Game Winners
chua***********an94@hotmail.com
aliy***********u081@gmail.com
bruc**********mars@gmail.com
Exclusive Discount Pack valued at $100 x1 (Includes 1x $50 off orders over $400, 1x $30 off orders over $200, and 1x $20 off orders over $100)
sean********1833@gmail.com
REDMAGIC GO Power
geff**********iver@gmail.com
enca**************do33@gmail.com
myke******e421@gmail.com
monk***************sock@gmail.com
unfo*********ig68@gmail.com
REDMAGIC Merch Packs
(Includes a REDMAGIC Baseball Cap + REDMAGIC Building Blocks + REDMAGIC Mora Plushie + REDMAGIC Frisbee + REDMAGIC Mora Tote)
thek**********26pg@gmail.com
alix********wong@yahoo.fr
guly**********r936@gmail.com
drag*************nciu@gmail.com
take********aros@gmail.com
Didn’t win this time? Stay tuned—more exciting campaigns are coming your way soon!
REDMAGIC Astra 2 Dual-Sided Folio Case REDMAGIC Astra 2 Dual-Sided Folio Case
Protect and enhance your REDMAGIC Astra 2 Gaming Tablet with the Dual-Sided Folio Case. Featuring a premium, skin-friendly silicone finish, full front-and-back protection, smart wake/sleep functionality, and a magnetic foldable stand for multiple viewing angles. Designed for durability, comfort, and everyday convenience.
$24.90
$24.90
