REDMAGIC-10S-Pro-Unstoppable-Gaming-Power-in-Your-Hands
Every few years, technology leaps into the future to create something revolutionary that pushes the limits of what’s possible – and when it comes to pushing boundaries, we stay fully committed at REDMAGIC. This is why we’re excited to unveil our latest creation: the REDMAGIC 10S Pro. Hot on the heels of our 10 Air release, the 10S Pro promises to take gaming to the next level with power that is “Unstoppable. Unbeatable. Undisputed.” The 10S Pro was designed to elevate your gaming experience with undeniable performance, superior cooling, and exhilarating endurance. Now, let’s get to know the 10S Pro a little better and learn more about its exclusive new features.
Performance Unleashed
Naturally, we like to stay ahead of the game at REDMAGIC and give our gaming smartphones the latest and greatest technology on the market. The 10S Pro comes equipped with the Leading Version of the latest Qualcomm Snapdragon 8 Elite chipset, combined with our very own upgraded AI RedCore R3 Pro to enhance gameplay and prioritize performance. This winning combination gives the 10S Pro superior agility and seamless processing power for the most demanding AAA games, while still being more than capable enough for your daily tasks.
Designed for Winners
When we created the 10S Pro, we had a vision of combining style with practicality to ensure the best of both worlds. The 10S Pro is crafted from a premium transparent metal body with an ergonomic, flat-back design, offering a chic look that’s easy to hold for extended gaming sessions. The phone also amplifies the gaming ambience with dynamic RGB lighting, strategically placed shoulder triggers for immersive gameplay, and a customizable Magic Key for instant access to Game Space and everyday functions.
Visionary Visuals
The 10S Pro comes with a sleek 6.85-inch screen with a 1.5K full display with exclusive BOE custom AMOLED. With a 95.3% screen-to-body ratio, 2000 nits of peak brightness, and a 2688 x 1216 resolution, you’re bound to be impressed by the stellar visuals in store for you. The phone also features a 100% DCI-P3 wide color gamut for vibrant hues that captivate. With a 144Hz refresh rate, 2,500 Hz instant touch sampling rate, and 960Hz multi-finger touch sampling rate, you can also ensure that your graphics and loading times are seamless at every turn.
To push your visuals into overdrive, the new and improved RedCore R3 Pro uses smart power management and up to 2K super-resolution enhancements when connected to compatible external displays. For the avid gamers, you can also make use of our 144Hz frame boosting for smoother, more immersive visuals in several popular games.
As much as we want to push you to win, we also want to keep you safe while you do it. This is why the 10S Pro comes fitted with customizable TÜV Rheinland-certified low blue light eye protection that reduces blue light emitted from the screen to relieve eye fatigue.
Fueled to Dominate
Now, the 10S Pro is designed to be unstoppable with a hefty 7,050 mAh battery capacity. As the largest battery available for flagship smartphones, you can seamlessly get up to 52 hours of power for daily use with the 10S Pro. The 80W fast charging will also keep you ready to go with a full battery in just 40 minutes, while our unique charge separation feature safeguards your battery from taking on any damage during intense gaming sessions.
Breaking Boundaries Without Breaking a Sweat
The mark of a superior gaming smartphone is its cooling capabilities. This is why we push the limits to give you the best. Our 10S Pro is fitted with an enhanced ICE-X 10-layer cooling system that uses Liquid Metal 2.0, a massive 12,000mm² vapor chamber, and a 23,000 RPM high-speed fan for elevated heat dissipation. The phone uses
The Liquid Metal 2.0 has a thermal conductivity of 200 W/m·K and provides 30% more coverage. We’ve also gone ahead and repositioned it directly above the CPU to ensure up to a 5°C drop in CPU temperature and significantly better thermal performance and gaming stability.
The phone’s vapor chamber also uses graphene and copper insulation to maintain stable frame rates, prevent throttling, and provide optimal gameplay, even under strain. Meanwhile, our signature high-speed turbofan with customizable RGB lighting uses shark-fin blades to efficiently dissipate heat at a silent 4 dB.
Gaming Made Easier
The 10S Pro was built to elevate your gaming capabilities in every way. The phone uses a winning mix of customizable features to elevate your gaming experience and amplify the ambience to every victory. The 520 Hz strategically positioned shoulder triggers offer seamless precision and responsive controls in fast-paced or competitive games, while the customizable RGB lighting on the phone allows you to really set the mood and add an interactive touch to each game.
As always, you can enjoy our unique X-Gravity feature as well and get to play the most demanding games at the touch of a button. Whether you’re screen casting or connecting keyboards, console controllers, and other devices, you can always count on us to make every game an epic experience.
Your 10S Pro also pushes your gaming skills into fifth gear with multiple plugins that improve your aim and capabilities. Magic Touch also allows you to enjoy instant responses, fingertip sensitivity, rapid first-frame rendering, and subsequent reporting, which work together to provide instant response times and seamless visuals for fast-paced gaming or heavy processing.
Using seamless 144Hz frame boosting, the 10S Pro was able to effortlessly conquer every level of Call of Duty Mobile without breaking a sweat. For now, your REDMAGIC 10S Pro’s Frame Rate Boosting feature is compatible with several leading games, including Genshin Impact, COD Mobile, Clash of Clans, Wild Rift, Honkai Impact 3, Arknights, Arena Breakout: Infinite, Clash Royale, Pokémon Unite, and many more still to come.
A Step Ahead in Our Own League
For us at REDMAGIC, we believe that continuous improvement is the key to success. This is why we stay in competition with ourselves in the smartphone gaming industry, with leading devices that are always leagues ahead. For the 10S Pro, you could easily compare its performance to the REDMAGIC 10 Pro and see how we’ve pushed the envelope a step further. The 10S Pro boasts 30% better CPU capabilities, a 30% GPU enhancement, and a 40% better NPU AI performance.
Seamless Storage
Another great feature of the 10S Pro is its extensive memory and storage options. The phone comes with LPDDR5T RAM in 12GB, 16GB, or 24GB variants to provide rapid multitasking and smooth gameplay during intense usage or heavy gaming, with 13% faster data transfer speeds and 30% better power efficiency. The phone also features UFS 4.1 Pro storage to load apps and data in a matter of seconds, with storage options up to 1TB, giving you 3% faster read speeds and 10% quicker write speeds.
Convenience Powered by AI
With the 10S Pro, you can enjoy instant AI assistance from Google Gemini, which helps you with any number of complex or demanding tasks. From AI photo searches to image editing, your AI will put in the work so you don’t have to. Other AI features on your 10S Pro include circle to search, real-time translations, call subtitles, and more. To match your dynamic and fast-paced lifestyle, Google Gemini also allows you to easily convert spoken languages into subtitles during calls, with real-time translations. You can also set the call language to enable automatic and real-time translations with playback. Our unique Mora AI-powered assistant can also analyze player conversations and encourage interactions.
Capture Life as it Happens
While the camera setup on most gaming smartphones doesn’t always get the limelight, our 10S Pro is dedicated to providing clarity in every shot. The phone features a 50MP main and 50MP ultra-wide rear camera, which both provide clear details and stability within every picture. This phone also sports an upgraded 16MP front camera that uses AI optimization to ensure clearer and more natural selfies.
Amplifying Every Win
The 10S Pro is all about giving you a bold and big experience at every turn. This means turning up the volume to give you the best audio, along with every other enhancement. Equipped with DTS-X certified three-dimensional dual 1115K Speakers, the 10S Pro ensures exceptional audio and high-fidelity sound. The 0815 super linear motor also adds to every moment with powerful vibration feedback for an even more immersive experience. Whether you're gaming or watching a movie, the dual speaker setup and intense vibration feedback will keep you engaged.
 Stay Connected, Stay Ahead
The phone’s dual-band 5G Wi-Fi also provides 20% faster download speeds and 2ms ultra-low latency. You can also enjoy NFC support, which includes compatibility with Google Pay and QuickPass. The dual SIM compatible gaming smartphone will always keep you connected with infrared remote-control capabilities, and under-screen fingerprint recognition keeps your phone and data safe. The 10S Pro runs on the latest REDMAGIC 10.5 OS and has Elevator Mode and High-Speed Rail Mode to ensure stable connectivity on the go. The IP54 rating also keeps your phone protected from dust and splashing from any direction.
Step Into the Future with the 10S Pro
We always strive to give our fans and community the best devices and features with every release, and we’re thrilled to see what you make of the new 10S Pro. Designed to be efficient and enduring, this gaming beast dominates across every field to give you superior performance and capabilities. If you’re looking to stay ahead of the game, invest in the REDMAGIC 10S Pro today and unlock your winning streak.
