Real-Warriors-Never-Overheat-REDMAGIC-ICE-13.5-Cooling-System
In the heat of battle, every advantage counts; speed, endurance, and unique skills can make all the difference. For the true gaming warrior, nothing should stand in the way of victory, not even the threat of overheating.
The REDMAGIC 9 Pro guarantees gamers The Chill that Never Quits with the ICE 13.0 cooling mechanism, which drops temperatures by up to 18°C. The REDMAGIC 9S Pro is equipped with the cutting-edge ICE 13.5 cooling system which is even colder than the original, designed to keep your gaming weapon cool and unstoppable in the most intense gaming sessions.
Maintains the Best Temperature in Battle
At the core of all REDMAGIC gaming smartphones and the ICE 13.5 cooling system is the built in turbo fan. It features enhanced airflow capabilities with a fan that spins at up to 22,000 RPM for ultimate cooling to ensure you always stay ahead in the game. Paired with a 30% improvement in heat dissipation from the REDMAGIC 9S Pro’s perfectly crafted alloy frame, this cooling system keeps your device running smoothly during marathon gaming sessions.
Customization is the key to unlocking any warrior’s unique fighting skills. The REDMAGIC 9S Pro continues the customizable RGB light trend around the fan and shoulder triggers, allowing you to tailor your gaming setup with vibrant lighting, and create a personalized atmosphere that fuels your drive for victory. Whether you prefer a subtle glow or a dazzling light show, the REDMAGIC 9S Pro adapts to your style, offering an incredible 16.8 million color options to enhance your gaming experience.
Frost Cooling Gel: Boosting Thermal Efficiency by 20%
The magic of the ICE 13.5 cooling system doesn’t stop there. It features a unique layer of Frost Cooling Gel, an advanced material that enhances thermal efficiency by an impressive 20% compared to previous conductive materials.
Testing in the REDMAGIC lab reveals that the Frost Cooling Gel drops the motherboard temperature by an additional 1.5°C, taking the temperature drop from 18°C to 19.5°C.  The additional temperature drop gives you the edge you need to maintain peak performance, resulting in an overall increase of peak power by 0.3W. These stable temperatures ensure your REDMAGIC 9S Pro continues to unleash its full potential and the Warrior Within when it matters most.
Industry-Leading Vapor Chamber
Dominating the battlefield requires the best equipment, and the ICE 13.5 cooling system delivers with its industry-leading Vapor Chamber. Boasting a surface area of 10,182 mm², this is the largest cooling Vapor Chamber in any mobile device. Its stepped design reduces the CPU core temperature by up to 25°C, ensuring that even the most demanding games run smoothly and efficiently, as noted by Android Authority
This cutting-edge cooling technology not only boosts performance but also extends the lifespan of your device, allowing you to stay in the fight longer. With the REDMAGIC 9S Pro, you can push your limits without worrying about overheating or causing thermal damage to your device.
Ready to Stay Cool Under Pressure?
In the world of mobile gaming, victory belongs to those who can stay cool under pressure. The REDMAGIC 9S Pro, equipped with the ICE 13.5 cooling system, ensures that overheating will never be the obstacle that stands between you and your triumphs. This cutting-edge cooling technology not only boosts performance, but by preventing thermal damage, it also extends the lifespan of your device allowing you to push your limits without fear.
Real warriors never overheat. Embrace the ultimate gaming experience with the REDMAGIC 9S Pro and Unleash the Warrior Within.
From $749.00
From $749.00
From $119.00
From $119.00
