Pushing performance further is the ideal goal of any gaming device. To keep up with growing processing demands, gaming smartphones in particular have had to adapt over time, becoming faster, more durable, and better at upscaling. Today, smartphones have to keep up with almost PC-like speeds, which is why REDMAGIC has always entrusted our revolutionary processing to the bright minds at Qualcomm.
In partnership with Qualcomm, REDMAGIC has continuously delivered superior gaming devices with ground-breaking performance stats across the board. Now, we’re happy to include the leading version of the Snapdragon 8 Elite Gen 5 in our latest flagship: the REDMAGIC 11S Pro. Today, we’ll be focusing on how the liquid cooling system on the 11S Pro works to elevate the performance of this world-class chipset.
Pushing Beyond Performance
Since its humble beginnings, Qualcomm has set out to make chipsets that push devices to the limit and deliver advanced processing that makes tasks simpler, faster, and more efficient. Built to impress, the REDMAGIC 11S Pro also exemplifies elevation and dedicated performance. As the world’s fastest mobile CPU around, the Qualcomm Snapdragon 8 Elite Gen 5 Leading Version processor expands the possibilities and opens up a new world of speed.
Built on a 3nm N3P process, this powerhouse smartphone is built with a 3rd generation 2+6 Oryon™ CPU architecture that clocks up to 4.74GHz, alongside an Adreno™ 840 GPU that delivers up to 1,300MHz. This ensures superior prowess, with up to 19% upgraded CPU performance, 24% better GPU power, 39% enhanced NPU, and 33% lower latency.
This is all then further amplified with up to 16GB of upgraded LPDDR5X RAM and up to 512GB of UFS 4.X storage to improve loading speeds, multitasking, and gameplay smoothness. Our updated RedCore R4 gaming chip also extends performance to your graphics, providing customizable in-game effects and Qualcomm-driven, 2K super-resolution for smooth visuals. Now, let’s see how this dynamite processing power is enabled by the 11S Pro’s advanced liquid cooling.
Power That Runs Cold
As we move into the cooling element of the 11S Pro in relation to its elite processing, we have to mention that our proprietary enhanced CUBE Engine 3.0 is also used alongside our pioneering cooling systems to dynamically allocate CPU, GPU, memory, cooling, and touch resources in real-time. This ensures higher FPS stability, faster responsiveness, and reduced power consumption and heat.
Inspired by our fans, REDMAGIC chose to engineer a cooling solution that would elevate performance while actively reducing heat. This is how our AquaCore Cooling System came to life. Liquid cooling has been revolutionary for us at REDMAGIC, allowing our 11 Pro to become the world’s first mass-produced liquid-cooled smartphone. Now, the 11S Pro takes up the mantle with a few tweaks of its own to up the ante.
Liquid cooling systems are built on a simple principle of thermodynamics, allowing the flow and circulation of liquid to essentially move heat around and away from critical components inside a device. The methodology has a long history in the gaming industry, mostly for PCs and high-performance computer systems; however, we’ve pioneered and perfected it now for the mobile gaming sector at large.
Within the 11S Pro, the AquaCore system uses the same fluorinated AI server-grade flowing liquid that visibly circulates across the length of the phone’s back. However, this time, the liquid passes over a much larger 105 mm² space, radically improving heat dissipation and ensuring 2 - 3°C lower temperatures than the REDMAGIC 11 Pro during peak performance.
The 11S Pro also comes fitted with the industry’s largest 13,116 mm² vapor chamber, featuring a dual-sided raised thermal structure that reaches from the camera to the bottom speaker for 50% better heat dissipation, and enhanced Liquid Metal 3.0. The 11S Pro is also the only smartphone in the industry to actively feature both liquid and air cooling with an IP68-rated, waterproof, and dust-resistant 24,000 RPM turbo fan that keeps your game running cool and improves liquid cooling circulation efficiency by 10%. So, how does liquid cooling elevate processing power?
Liquid Cooling Pushes Power
The basic correlation between an advanced liquid cooling system and a powerhouse processing chip is what the cooling allows the chipset to get away with. Think of the Snapdragon 8 Elite Gen 5 Leading Version as a fantastically fast car engine looking to be unleashed. Our 11S Pro cooling system simply provides the right traction control to channel that energy in the right direction for a longer time.
While many types of cooling systems exist, liquid cooling is especially suited for high-performance processing devices, compact systems, and overclocked CPUs, all of which perfectly fit the specs of the REDMAGIC 11S Pro.
Liquid cooling has always provided a host of benefits to processing performance throughout the history of gaming. Some of the main advantages include:
Stable Frame Rates: With liquid cooling, you get to enjoy sustained peak performance for longer periods, allowing your device to keep up with demanding graphics and processing without overheating or thermal throttling.
Extended Gameplay: Naturally, liquid cooling allows you to game for longer without any lag or an uncomfortably hot screen.
Faster Heat Dissipation: Liquid cooling systems have the added benefit of being much faster, with several cooling mechanisms working together to flush out the heat, allowing you to get on with your game more quickly.
Improved Multitasking: A cooler processing chip means more efficient multitasking, which is crucial for demanding AAA games and intensive tasks.
Improved Comfort: A hot phone makes for an uncomfortable grip and burning fingertips. Liquid cooling ensures a more comfortable, cooler grip on your device, even during intensive gameplay.
Battery Protection: Heat is the enemy of battery health. With prime liquid cooling in place, your battery system stays cool and protected while it helps the processing push beyond limits.
The enhanced AquaCore system evenly distributes heat across the phone for rapid dissipation and cooling, keeping your fingertips from burning up as the 8 Elite Gen 5 Leading Version amps up the gameplay for you. Ultimately, the processing and cooling components work in tandem to ensure a seamless, efficient, and superior gaming experience that prioritizes your needs. The REDMAGIC 11S Pro offers a seamless solution that combines power with safety, giving you superior gameplay that never compromises and never backs down.
Q: What is the difference between the 11 Pro processing chip and the 11S Pro processing chip?
A: The REDMAGIC 11 Pro is fitted with the Snapdragon 8 Elite Gen 5, which features an Oryon™ CPU with a clock speed of up to 4.61 GHz and the Adreno™ GPU for exceptional graphics and smooth gameplay. The 11S Pro is fitted with the Leading Version of the same flagship processing chip, which uses a 2+6 Oryon™ CPU architecture that clocks up to 4.74GHz, with a 19% upgraded CPU performance and 24% better GPU performance. While both chipsets ensure superior speeds and processing, the leading version of the 8 Elite Gen 5 offers enhanced performance.
Q: How is the 11S Pro’s liquid cooling system different?
A: The 11S Pro is the only gaming smartphone in the industry to feature both water and air cooling. It also delivers 2 - 3°C lower temperatures than the REDMAGIC 11 Pro under peak performance conditions.
Q: How does liquid cooling elevate processing power?
A: Liquid cooling provides consistent and more reliable cooling that dissipates heat faster. This allows processing chips to embrace their full potential without the threat of lagging, thermal throttling, and overheating.
REDMAGIC 11 Pro
Take a Sneak Peek at Our New REDMAGIC 11 Pro
REDMAGIC VC Cooler Series
