At REDMAGIC, we believe that excellence demands innovation. Upgrading and enhancing existing technologies is the only way to fully realize their potential. This is the core understanding that we hold onto in our design process. Now, we can finally showcase what our ambitions have led to with the dawn of the REDMAGIC 11S Pro.
The long-awaited 11S Pro comes hot on the heels of the massively successful REDMAGIC 11 Pro, quickly becoming a worthy successor across all aspects. Refined, elevated, and iconic, the 11S Pro is designed to set a new standard in mobile gaming genius. Now, let’s look at what you can expect from our latest flagship phenom.
REDMAGIC 11S Pro in Nightfreeze and Subzero colors
The Future of Mobile Gaming, Now
When we hit the board to craft the successor to the impressive 11 Pro, we knew that we would have to build something worthy of our fans’ loyalty. While we’ve always pushed for refined specs and pioneering features, the 11S Pro quickly became a passion project designed to enthrall. Armed with enhanced processing power, an upgraded cooling system, and speeds as you’ve never seen before, the 11S Pro is primed to do more and go further. Now, without further ado, let’s explore the main highlights you can look forward to.
Elevate Your Elite Power
The mighty beast behind the 11S Pro is the main pull for the smartphone, without a doubt. At its core, the device is fueled by the world’s fastest mobile CPU around. The leading version of the Qualcomm Snapdragon 8 Elite Gen 5 processor pushes the 11S Pro into the big leagues, ensuring faster processing and seamless performance.
Built with a 2+6 Oryon™ CPU architecture and an Adreno™ GPU that clocks up to 4.74GHz, the 11S Pro never falters when it comes to speed, racing ahead with a 19% upgraded CPU performance and 24% better GPU performance. The lightning-fast smartphone also comes fitted with up to 16GB of upgraded LPDDR5X RAM and up to 512GB of UFS 4.1 storage to improve loading speeds, multi-tasking, and gameplay fluidity.
To push optimization further, the 11S Pro uses our proprietary enhanced CUBE Engine 3.0 to dynamically allocate CPU, GPU, memory, cooling, and touch resources in real-time. This ensures higher FPS stability and faster responsiveness, while also reducing power consumption and heat for smoother frame rates in complex scenes and steadier performance.
Our updated RedCore R4 gaming chip then goes on to provide customizable in-game effects and Qualcomm-driven 2K super-resolution, delivering buttery visuals while intelligent power management extends your battery life and keeps the device cool during intense sessions.
Our Flow Just Got Colder
With such a fiery processing beast under the hood, the 11S Pro demands extensive cooling capabilities to keep up. While the 11 Pro quickly broke ground as the first mass-produced liquid cooling smartphone, the 11S Pro goes a step further in the same icy vein with an upgraded version of our AquaCore liquid cooling system.
Once again, we’ve used an AI server-grade flowing fluorinated liquid alongside active air-cooling technology to stay cooler for longer. However, this time, our innovative cooling system has been upgraded to a larger 105 mm² area for improved heat dissipation. This ensures 2 - 3°C lower temperatures than the REDMAGIC 11 Pro during peak performance.
The 11S Pro also sports the industry’s largest 13,116 mm² vapor chamber with a dual-sided raised thermal structure that seamlessly reaches from the camera to the bottom speaker for 50% better heat dissipation. Alongside enhanced Liquid Metal 3.0 and our IP68-rated, waterproof, and dust-resistant 24,000 RPM turbo fan, the 11S Pro keeps your game running cool and improves liquid-cooling circulation efficiency by 10%, all while being drop-resistant, cold-resistant, and non-conductive for safe, durable, and compact cooling.
Sharper in Every Way
Stay immersed in every moment with a 6.85-inch full-screen AMOLED display, a fluid 144Hz ultra-high refresh rate, and notch-less X10 under-display technology that ensures seamless, vibrant, and sharper visuals alongside an expanded 1.5k 2688 × 1216 resolution, advanced touch controls, and a 95.3% screen-to-body ratio.
Magic Touch 4.0 also ensures a rapid 3,000Hz instant touch sampling rate and 360Hz multi-finger touch sampling rate for 10% improved touch accuracy and enhanced stability to reduce mis-taps during intense gameplay. Wet-hand touch support and a 3D ultrasonic fingerprint sensor further provide efficient security and precision inputs, despite hand washing, sweat, or rain.
Designed to See More
The 11S Pro was sculpted to elevate your everyday life, with a fully flat build, dynamic RGB lighting, and a uniquely transparent back that allows you to see the flowing liquid in our pioneering cooling system in action. Crafted in a sleek, premium aluminum alloy frame with durable Corning® Gorilla Glass 7i, the 11S Pro is comfortable to hold and effortlessly stylish.
Built for Victory. Forged for Battle.
An elite gaming smartphone should give you elite gaming power, which is why the 11S Pro was built to elevate your speed, processing, and gameplay capabilities in one swoop. Engineered around the Snapdragon Elite Gaming, our RedCore R4 gaming chip, and superior Game Space features, the 11S Pro was built for battle. Easily play Genshin Impact for up to 60 minutes using the highest graphics settings and get a 60.93 average FPS, higher than the 11 Pro’s 60.90.
AI frame interpolation 2.0 ensures 33% lower latency for gameplay that never lags, while a Synaptics 3910V chip also offers superior display quality with up to 37% improved accuracy, ultra-low latency, and up to 2,592 Hz PWM dimming. SGS and TÜV Rheinland-certified low blue light reduction also aim to minimize eye fatigue during long hours of gaming, especially at night.
Keep Up Effortlessly
A healthy, large battery gives you the stamina you need on the road to victory. The 11S Pro comes fortified for the battlefield with a massive 7,500 mAh battery, easily ensuring up to 34.1 hours of power for daily use, 7.4 hours of Genshin Impact gameplay at full frame rate, and 12.5 hours of YouTube live streaming at 1080p using maximum brightness and volume.
The powerhouse battery also comes alongside 80W wired and wireless fast charging support, giving you versatility and convenience in how you refuel after or during every game. The 11S Pro also uses our first-ever two-way, reverse charging system to keep all your devices powered up and ready to go, along with Charge Separation to protect your battery from damage if you need to recharge while you play.
Ready When You Are
Strike your best pose with a 50MP OIS main camera, a 50MP ultra-wide camera, and a 16MP front camera. The 11S Pro elevates your camera’s capabilities with optimized imaging algorithms for enhanced photo quality and crystal-clear day-to-day capture. To keep you immersed in every moment, the 11S Pro also comes fitted with large 1015 + 1115e dual speakers and optimized 0815 x-axis linear motor 4D vibrational feedback, alongside 520 Hz shoulder triggers for rapid responsive control, especially in high-speed FPS and MOBA games.
Performance Meets Purpose
The 11S Pro offers versatility and durability that make it much more than a simple gaming phone. The phone comes armed with IPX8 dust and water resistance for added durability in every condition. A 360° antenna, dual-band 2.4GHz + 5GHz Wi-Fi connectivity, and dual SIM, NFC, Google Pay, and USB 3.2 Gen 2 support also keep you connected, while the phone seamlessly provides second-screen display and control expansion on tablets.
Google Gemini's AI assistance is also there to help you solve complex problems and provide essential services, such as AI photo search, image editing, circle to search, real-time translations, and call subtitles. Our enhanced and efficient REDMAGIC AI input method also generates copy faster and with more accuracy. The device also uses REDMAGIC OS 11.5, which is based on Android 16 for a much smoother and more intuitive experience.
Evolve with the REDMAGIC 11S Pro
Pushing beyond the best you can do is how you achieve excellence. While most manufacturers might simply strive to stay afloat in the industry, we choose to actively stay ahead. The REDMAGIC 11S Pro offers all the power, precision, and endurance that you should come to expect from innovative expertise, along with so much more that’ll keep you surprised. With leading processing speeds, inspired liquid cooling systems, and exceptional performance, we are beyond excited to finally introduce you to a refreshingly elevated standard in the mobile gaming industry. Say hello to more than just a gaming upgrade, say hello to gaming excellence.
What are some of the upgraded highlights of the REDMAGIC 11S Pro?
The main highlights of the REDMAGIC 11S Pro include the leading version of the Snapdragon 8 Elite Gen 5 processor, the upgraded liquid cooling system, a transparent rear design, and enhanced performance capabilities.
What’s so special about the 11S Pro’s liquid cooling system?
The 11S Pro is the only gaming smartphone in the industry to feature both water and air cooling. It also delivers 2 - 3°C lower temperatures than the REDMAGIC 11 Pro under peak performance conditions.
Does the REDMAGIC 11S Pro feature wireless charging?
Yes, just like the 11 Pro, the 11S Pro also features both wired and wireless 80W fast charging support.
What color and configuration options does the REDMAGIC 11S Pro come in?
The REDMAGIC 11S Pro will be available in two colors: transparent black Nightfreeze with 12GB + 256 GB and 16GB + 512GB configurations, and transparent silver Subzero with a 16GB + 512GB configuration.
What kind of audio port does the 11S Pro have?
The 11S Pro uses a USB Type-C 3.2 Gen 2 port that’s fully loaded for all your connectivity needs.
