We’ve all been there: you’re pushing through the last few levels or facing off against the final boss after grinding for hours, and suddenly you get the dreaded ‘low battery’ notification. Then, with burnt fingertips from an overheated screen, you plug your phone in to charge and play a new game – the waiting game. Battery power is a critical part of your gaming experience, especially for mobile gamers.
Keeping your battery healthy and maintaining solid charging habits goes a long way in improving your power consumption on your gaming smartphone. So, today, we’ll be looking into how you can optimize your battery life in the best way possible without hindering your gaming experience along the way. First, let’s look at what makes a battery good in a gaming smartphone.
What Do Great Batteries Have?
Gaming smartphones require a lot more power than regular smartphones. This is due to their demanding processing capabilities, gaming-intensive features, and the need to provide hours of gameplay. Essentially, a gaming smartphone has a lot going on and needs a battery that can keep up. These are some of the hallmark traits of what you could call a respectable battery in a gaming smartphone:
  • Large Battery Capacity: It comes as no surprise that a large battery capacity is one of the top indicators of an effective gaming device. A larger capacity means more power, which means more gaming and more energy for demanding tasks.
  • Intelligent Cooling: Gaming devices typically rack up a lot of heat during intense sessions, most of which is around the battery. A proper gaming device integrates cooling systems that actively keep the battery and important components from overheating.
  • Compact Design: While a larger battery often meant a larger frame, science has now allowed us to make compact batteries to fit the sleek models of today, without compromising on effectiveness.
  • Effective Power Management: Optimizing your battery life requires specific adjustments and features that reduce power drainage and encourage healthy charging habits.
  • Versatility: In the evolving tech world, it’s important to always stay ahead of the buzz with innovative designs and features, like wireless charging and reverse dual charging. Despite its popularity, many fans still haven't heard that the REDMAGIC 11 Pro actually features our very first wireless charging support feature for truly advanced and convenient refuelling, alongside dual reverse charging to even keep other devices powered up.
Now that we know what we should be looking for, let’s focus on what makes batteries suffer the most in gaming smartphones.
Why Is My Battery Dying So Fast?
As we’ve mentioned before, gaming smartphones demand a lot of power to fulfill their respective tasks. This means that your battery will likely be under a lot of strain during intense gaming sessions. Let’s review some of the top culprits of battery depletion.
  • Extended Usage: Naturally, using your phone for long periods of time will waste the battery a lot faster than normal.
  • Intense Gameplay: Most gaming titles today demand fast processing and rapid multitasking to operate effectively. This is another big drain on your battery life.
  • Drastic Charging Habits: While charging is a good thing for your battery, you can go about it in the wrong way at times. Charging your device too much or allowing your battery to deplete entirely before connecting a charger can damage your battery.
  • Constant Heat: As we mentioned, heat is a natural part of intense gameplay; however, if you don’t use a cooler or a device with a solid cooling system, you will damage your battery with all that heat.
  • Peak Brightness and Refresh Rates: Optimizing your phone settings is key to maintaining healthy battery consumption. Try to keep your screen brightness at minimal and adjust refresh rate settings according to the needs of the game to meter out only what’s necessary at the time.
While you can’t prevent any type of battery depletion from affecting your gameplay, you can work your way around the main challenges to maintain healthy battery habits. Let’s take a look at some of the best practices you can implement to keep your battery healthy and thriving.
Battery Health Best Practices
Battery health can be a temperamental issue with obstacles in every direction. The best way to keep your device’s battery happy and healthy is to stick to a strict set of guidelines along the way.
Turn Down the Lights: As much as we all love that dazzling display, it will drain your battery a lot faster. To maintain a solid battery life, it’s important to keep your screen’s brightness low in most settings. Apart from taking it easy on your battery, it also protects your eyes.
Charge Separation: A key element of our REDMAGIC gaming smartphones is our Charge Separation feature. Also known as bypass charging, this allows you to power your device directly from the power source, without affecting the battery. This allows you to continue your game while you charge your phone, a feat which would normally damage your device. However, with Charge Separation, the battery level remains unchanged while plugged in, drawing power directly from the circuit instead of the battery.
Keep Your Cool: Heat management is a very large chunk of battery health optimization. Keeping your phone from overheating gives you more time to game while reducing your power consumption levels. Fit your smartphone with a cooler or turn to our REDMAGIC range for devices that integrate active, liquid, and innovative cooling systems across the board.
Build a Routine: Gaming can make you lose track of time pretty quickly, getting you immersed in the level so much that you forget how long you’ve been playing for. Setting a timer or establishing a healthy gaming routine allows you to make time for charging and rest, giving both your body and battery a well-needed break between the grind.
Optimize Your Settings: With REDMAGIC, you get the unique ability to fully customize your performance as well, which will directly impact your battery life. Try to stick to Eco or Balance modes to ensure efficient battery health while you game.
Use Original and Quality Products: Do not waste time on low-quality charging devices, power banks, adaptors, or cables. These can seriously damage your battery in the long run. Always use the power adapters and accessories built for your phone to prevent wear.
Keep Healthy Charging Habits: Your battery life is directly affected by how well you charge your phone. It’s recommended to always keep your battery above 20% battery and just below 80% at all times for optimum battery health.
Stay Updated: Having the latest software updates ensures that your phone has the latest upgrades and features from developers. This includes battery optimization settings and modes to preserve your battery’s health and longevity.
The basic gist of battery maintenance comes down to optimizing your device settings, being responsible when charging, and making use of the advanced charging tech and features at your disposal.
Get Powered Up
From the start of our journey in the gaming industry, we’ve been committed to innovative technologies that make life simpler for gamers. Armed with a long line of contenders, REDMAGIC’s battery evolution showcases a passion for intelligent engineering and smart gaming. From our tablets to our gaming phones, we’ve integrated the latest battery tech available to keep your game going – safely, seamlessly, and healthily.
Average GPU Temp While Gaming
Average GPU Temp While Gaming: Safe Ranges, Hotspot vs Core, and Fixes
Dissipator Band? You Probably Mean a Phone Thermal Pad—Do You Even Need One?
CPU Temp While Gaming
CPU Temp While Gaming: Normal Ranges, Monitoring, and Quick Fixes
